Is it necessary to use insulated chimney liner inside a larger insulated metal chimney/flue?
trickyrabbit
3
Colorado
The wife wants to install a new EPA 2021 stove. We currently have what I assume is a custom built metal fireplace with refractory panels in the back, sitting on top of a brick and marble/granite hearth. The current flue is about 10" across and insulated. I assume I'd need to find out what it's rating is. It is on the inside of the house and goes straight up through the roof.
Anyway, she was talking about just having someone install a new chimney, cutting a new hole in the ceiling and roof. I think it is a bad idea. The wood stove we bought requires a "6 inch minimum diameter" stove pipe.
Could I just use 6" diameter stove pipe to connect it to the existing 10" pipe? Or would I need to run a 6" insulated liner inside the current 10" insulated metal flue? Or could I use plain, single wall stove pipe inside it?
I'm going to see if I can find a label on the current pipe with an inspection camera and will update.
I would post some pics of your current setup you want modify. I am sure people will have info that will help you.
Is the fireplace a prefab unit? If so what is the make and model?
[Hearth.com] Is it necessary to use insulated chimney liner inside a larger insulated metal chimney/flue?[Hearth.com] Is it necessary to use insulated chimney liner inside a larger insulated metal chimney/flue?[Hearth.com] Is it necessary to use insulated chimney liner inside a larger insulated metal chimney/flue?
