Is it possible to clean the creosote that's behind the shield inside the firebox on King 40?
Jerome P
38
West Central Wisconsin USA
Is it possible to clean the creosote that's behind the shield on the side panel inside the firebox?
Alongside this question would be, What's the long-term effect of never finding a way to get back there and clean out the deposit's that will eventually fill that space? I would think with moisture it would eventually eat its way through the sidewalls.
What would be nice would be a flexible wire brush that attaches to either a drill or oscillating tool. Hell, even a manual brush that would work would be great. What have others done that's effective?
I’ve wondered the same thing about my Princess. I can fit my fireplace poker kind of around the edges. When I’m burning low and slow for a while there’s a bit of build up back there.
I assume that is part of the reason you’re supposed to run the stove on high frequently. To burn that off.
Find a piece of banding strap that they use to hold items on a pallet and bend one end at a 90.
It won’t burn off. It will dry and flake off, sometimes in big sheets, but it stays back there. On the princess it can be cleaned. I do it with a thin rubber hose on an air compressor blow nozzle. Puff and scrape it to the rear where it falls out.
The king has a rear heat shield so I’m not sure how to clean this area.
Reactions: DonTee
