Is it worth installing a woodstove to existing furnace duct work?
trailrated
360
Maryland
For next winter I want to add a wood burner (stove) in the basement and be able to tie into my existing duct work using its fan to circulate the warm air. I don't think I want to go the whole big boiler route. Is it also possible to still be able to use the oil furnace as back up if needed? I want to use this year to research all I can about it, to be able to make a good decision. If anyone has this setup let me know how its working out for you. Please excuse my ignorance in all this, I'm new to wood burning and different systems from your basic woodstove.
There is not one answer. It depends on the layout of the ductwork and the woodstove you plan to use. Also, keep in mind that a gravity vent has a very different clearance requirement than a fan forced vent so it is possible with the wrong setup to create a fire hazard.
To connect my RSF to ductwork using the top gravity vent openings requires a special butterfly damper that will only open under the force of a fan. The reasoning is that the fan will dilute the hot air to reduce the temperature. The fan also has a high temp cutoff to prevent air that is too hot from entering the duct.
Back when I bought and installed my first RSF, I got 3 cords of nice seasoned Ash from an acquaintance who had his installation condemned. He had a wood burning furnace that gravity fed into his existing oil furnace ductwork but the ductwork was not rated for class B vent. Don't assume that because it is a wood furnace that it will have the same code requirements as an existing oil furnace.
Also, codes may vary by region WRT to using existing ductwork. In my area it is strictly against code to connect my wood stove to my existing natural gas furnace duct. I had to have separate ducting.
Awesome replies guys. This is the type of info I am looking for. While I continue to research all my options, I'll just continue to feed my little englander in the garage :)
