Hi group,
I have a Heatilator Constitution C-40 (installed in 2008) with a ceramic baffle board & ceramic blanket. The baffle board is cracked into 4 pieces (that still can join together tightly as one piece), but I am considering to replace it since have everything removed for my chimney cleaning this next week. Warranty is out for replacement after the 5 years. I see several ads for BOTH the board & blanket at upwards of $150! Blanket is still good though. Can I just use a piece of Micore 300 for this application? I see that the ceramic baffle board is rated at 2300 degrees Fahrenheit, but I don't see any specific flame/heat rating for the Micore 300? Anyone have knowledge & experience in using Micore 200 for baffle? If Micore is not a good option, does anyone have a recommendation as to a source for cheaper material?
I appreciate anyone's input.
Thanks,
Kevin
Thanks,
Kevin
Did you happen to find a reasonable source for the ceramic material?
