I thought I was getting the hang of using the everburn system. Tonight, I went through my usual routine before going to bed. I had a good bed of coals, loaded the stove full of fresh splits, waited for them to catch then re-engaged the everburn system. The rumble kicked in and I was reading typical temps. I have a magnetic pipe thermometer, 18" from the collar (top exit) on single wall pipe--it was hovering around 400*. However, when I shut the lights off to go up to bed, i noticed a red glow from behind the heat shield. After further review, it was the stove itself (in the rear) that was glowing from behind the heat shield. Is this normal for this particular stove? I have the primary air shut all the way down and like I said the everburn is engaged and rumbling along as it should. However, anything glowing red isn't good. Is my thermometer bad? Thoughts?
