I am getting everything prepped for my upcoming Woodstock Ideal Steel installation, and I ordered a modular hearth pad that has three interlocking pieces (https://www.amazon.com/dp/B01MSAG5ZP/?tag=hearthamazon-20). The IS requires minimum of 0.41 R value and this hearth pad has 1.03 and ember protection as it's micore 300 covered in powder coated 16 gauge steel. The sheet metal has interlocking pieces so an ember can't reach the floor below, however, there is a small gap between where the micore ends on one piece and begins on the next (about 1/4 inch or so). I will be putting this hearth pad partially on top of my existing marble fireplace hearth and partially on top of 3/4 inch plywood over a wood floor. One of the two seams where the pieces of the hearth pad meet (and where the gap is), will be directly under the middle of the stove and on top of the plywood, and the other will be a few inches in front of the stove (also on top of the plywood). Should I be concerned with this little gap in the micore or is it a non-issue. If it is a concern, I suppose I could try to get some micore 300 (or something else with at least R 0.42) to put below the hearth pad instead of plywood, but I can't go over 3/4 inch thick below the hearth pad or I won't be able to fit the rear vent flue. Any input is greatly appreciated. If it helps here's a link to the hearth pad manual (http://files.drolet.ca/upload/image...65.1860424340.1504699920-508711186.1502221010). And, by the way, the hearth pad, while very simple, looks really nice with a great finish and the seems don't look bad.
Thanks!
Thanks!
