Thanks. Ram 1500 hemi.Sweet pic. What is the truck with the straight pipes
Yes. You can see the pinhole on the flat cutside. Great fuelwood.....
Ive heard this mentioned a few times. What/where is the pinhole that you are talking about?
That was how I was taught to identify ash, if I could only have one wood to burn I would choose ash, it seasons quickly and burns pretty damn good with some good coals afterward. I got some ash from my brother in law last March, he delivered it righty after cutting and splitting from a huge tree he took down. I checked it with my moisture meter in November and it was all below 18%, I ended up burning one cord in the fall and I saved the other cord for next fall.It's on the flat cutside of the wood; look at the original pictures that he posted, and on the second shot looking straight at the flat cutside near the middle by the crack in the wood you will see a little round "pinhole"; I have found this to be consistent with Ash trees although I have seen this on a few other trees, but mostly on Ash.
180? Are you sure you weren't counting the "spaces" between the rings also?I have read that White Ash has only 32% moisture green. I can see it being below 20% fairly quick if split and stacked to dry for a summer. I get some nice Black Ash up here. It sure is a slow growing tree, the last one I cut was fallen and I counted about 180 rings at its 22" base.
I thought the Ash Borer hole was much larger than that.
Sure is!! That's funny. I worked that outage so I knew it was there. Just hung with this older guy and cut stuff up. Was still a ton when I moved onSully that is Ash. Is that Snuff Mill road I'm looking at? Small world my man. I saw that ash yesterday![]()
