Is this going to be safe and up to code?
Dmitry
1,153
CT
Yes, it would be ok. Is the brick fireplace being removed or will this be an extension to the existing brick fireplace hearth?
That the setup
As long as the hearth pad meets the dimensions required it will be ok. It should be 46" wide (or at least fit between the brick opening) and 42" long. However, the linked hearth pad is just an extension at 48" x 22" which is not the pad shown in the image on their webpage. That is not deep enough.
It might be easier to either leave the vinyl flooring out for the required hearth area (maybe paint the concrete?) or get a sheet of steel for a hearth pad. What is the dimension between the two raised hearth wings behind the stove?
