Is this the air intake for my harman 52i pellet stove? Why do I need to buy an outside air kit for $300 when i can just connect a flexpipe to this ?
LobsterParty
56
Boston
[Hearth.com] Is this the air intake for my harman 52i pellet stove?   Why do I need to buy an outside air kit for $300 when i can just connect a flexpipe to this ?
That is the intake for combustion air, not the OAK, & yes, you can attach a flexible metal tube at that location. If you are going to create a hole thru an exterior wall, I would suggest you use a short piece of pvc pipe to go thru the wall, with a 90 degree elbow turned downward on the outer end & seal any gaps with 30-year silicone. Connect your flex to the inside section of the pvc & attach a screen to the outside, covering the ID.. This will keep the critters out…
Reactions: LobsterParty
Thank you. Just finished the job. Working fine. Saved lots of money using scrap parts in the garage.
Total cost : I paid some guy off Craigslist 75 bucks to drill a hole with a SDS Max 3.5" core bit carbide tips.
  • [Hearth.com] Is this the air intake for my harman 52i pellet stove?   Why do I need to buy an outside air kit for $300 when i can just connect a flexpipe to this ?
