It was installed in 2023, but the bottom inner layer is totally smoothe.If this was DSP stovepipe then the bottom inner layer would be crimped. That's why I wondered if this is an older product. How old is the stove pipe?
This is what modern DSP looks like.
The chimney adapter is up top at the ceiling support box. Not at the bottom.
![[Hearth.com] Is this too much fire in Drolet Deco? [Hearth.com] Is this too much fire in Drolet Deco?](https://www.hearth.com/talk/data/attachments/337/337247-a6c32b943762b2ad4f578ab932a21772.jpg?hash=7PSlV9nhmN)
That may get you there if it fits the telescoping pipe. Check measurements.As Stovelark said, I think I'm missing this at the top: https://www.amazon.com/Metalbest-266244-Universal-Chimney-Adapter/dp/B004HAG792/ref=mp_s_a_1_12
If the DSP damper section fits the flue collar well then this may not be needed.I also think I'm missing this at the bottom by the stove: https://www.amazon.com/gp/aw/d/B007JVLFAC?ref=ppx_pt2_mob_b_prod_image
All I literally have on there right now is a DW telescoping pipe.
What do you mean by gap of the stove pipe?Great, that's a good pipe. It could be if the crimp at the top is inserted into the gap of the stove pipe. If I zoom in to the picture of the support box, that looks like that may be the case. If it's Ultrablack then their damper section is part UBD.
There is an inner and outer layer in double wall. Does the crimp at the top go between these layers?What do you mean by gap of the stove pipe?
The part sticking down through the box looks like this:There is an inner and outer layer in double wall. Does the crimp at the top go between these layers?
![[Hearth.com] Is this too much fire in Drolet Deco? [Hearth.com] Is this too much fire in Drolet Deco?](https://www.hearth.com/talk/data/attachments/337/337251-d8efd93f778dc28ac77baae51d54722c.jpg?hash=PHz8oa5GfO)
The crimp fitting for the damper was actually pretty tight. I had a second pair of hands help me force it down. It did push the inner wall of the DW stove pipe in to accommodate the crimp, which I'm sure added to the tightness. When I took it back off I had to have someone hold the DW while I reefed and wiggled on my homemade damper. I imagine if someone shoved a bit of Rutland Stovo (or something similar) in the remaining gap, that'd keep any smoke in. I'm also learning that even with my 25' chimney, this Alto Deco is actually able to downgrade the fire from "raging inferno" to "maybe a bit too much wood" levels, even at 600 degrees with a max load of wood. I don't know what sort of stress that'll put on the door or window seals in terms of wearing them out earlier.How tight (or loose) was the crimp fitting into the flue collar.
Note that draft is not going to be weaker when the temp is above 50ºF outside. In that case, leave the damper open. It may only be helpful when temps drop below 40 or lower, depending on the draft strength and how tightly packed the firebox is.
