I went to look at a Jetstream tonight. It's hard to say what shape it's actually in since according to the current owner it sat for 20 years in the original owner's barn, never used. He made a go of it last winter, but never really got his system working well, so states that it was never actually used very much once finally installed. Of particular concern is that the system did not have a properly sized expansion tank for the 600 gal welded steel storage tank (!), so at one point blew a weld (in the tank, not the boiler). The solution then was to run it as an open system. Not good. Nor did it have low temp return water protection that I could find.
Heartening was the enthusiasm with which the guys at Kerr (they own the design now) received his inquiries for manuals and parts (had to rebuild the inducer fan).
Is Slowzuki the only current forum member with one of these boilers? If so, how's it running? I understand they make quite a lot of noise...
I'm on the fence about buying it... as yet have no place to put it, nor radiator system to tie it into (next winter, hopefully). Mostly worried that this one season might have done irreparable damage.
