I'd argue that the 034 did just fine. Remember there is over 20cc difference between the 034 and our dear 460s! Joful's 036 at 61cc and of similar design, should be able to at least keep up with my bone stock (as far as I know) 034.That's why I use my 460 even with a 20 inch.
That style just doesn't work with the 036, unless I slow it down with a smaller rim.
In the back yard (note diameter of rounds scaled against 42" pallet):
In the driveway:
More in the driveway:
Come to think of it, I bet there's more than 8 cords there!
You need a 100cc (or more) saw to really have some fun with those big rounds![]()
Having some time running an 056, I'd pick up the 064 first every time.Thistle: You find me one in good shape for $500, and I'm your buyer!
However, aren't you the one of the crowd who talked me out of buying that 056 Magnum over the 064?![]()
Yeah... that 056 Mag was not a light saw! It did have about 10 extra cc's, though.
Truth be told, with the 28" bar, I can get thru a 50" tree pretty damn fast with the 064. Sometimes it would be nice to have a longer bar, so I didn't have to work these monster trees from both sides (sometimes one side is much less dangerous than the other), but I've been getting by pretty good with what I've got.
Ask & ye shall receive - (broken link removed to http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&actionType=singinformore&item=111121282595)That vintage Cannon 42" roller nose bar is worth $150 easily.
I will run a 32 on anything north of 50. I think it was 60.00 bucks for an es bar. Nice to have but hate when I need it.
As will that one, now that it's posted here!I recently resigned myself to only running saws with AV and chain brakes. Actually sold me last two saws without these features earlier this spring! I'm figuring I'm not going to find a 100cc saw with those features at my price point, though.
I should check out a bigger bar for the 064 (unless I stumble on a bigger saw cheap!). On a side note, I looked at Still E's and ES's when I bought the bars for my 064 and 036, but didn't like that they don't have a grease port, as I've had more than one sprocket tip fail cutting a lot of green. I went with a Tsumura Total bar on the 064 and a Windsor Speed Tip on the 036. Both seem to be great bars, and each gets one shot of grease at each chain swap, or the beginning of a day of cutting.
I have the OE stihl roller tip or whatever 20" bar on my 390. Its now 8 years old and has not cut as much wood as some of you guys but i bet it has an easy 30 cords on it maybe??? not locked up yet!As will that one, now that it's posted here!I recently resigned myself to only running saws with AV and chain brakes. Actually sold me last two saws without these features earlier this spring! I'm figuring I'm not going to find a 100cc saw with those features at my price point, though.
Yeah... I'm sure they're good. However, I had an interesting conversation with my local Stihl dealer, who sells and services a TON of saws for local pro's. They also process and sell what appears to be hundreds of cords per year behind the shop.
Me: Where's the grease hole?
Dealer: Stihl did away with them a few years back.
Me: Don't they have trouble getting jammed up with debris, with no way to push the crud out or re-lube?
Dealer: They're actually pretty good. We have very few complaints on them. They must have a good seal on that bearing.
Me: What do you run on your own saws?
Dealer: I prefer bars with grease holes on my own saws.
Then he pulled out the Windsor Speed Tip bar, and said that's what he's been running lately.
once in a while throughout the year (usually when I dress the rails on the bar), I like spray some degreaser or contact cleaner in the nose sprocket, and then pour a little bit of gear oil in the sprocket of my ES bars and spin them manually....That, combined with having my oilers turned up on my saws, seems to keep the sprockets in great condition. I'm like SmokinJ, I've got literally 125+ cord on my 28" ES bar, never had a nose sprocket issue yet......I've had smaller bars get a bit cranky (My MS230 had nose sprocket issues a while back) but never a problem with the ES bars..Wide tip version is 13 tooth sprocket instead of the standard 11. Less speed on the bearing.
Grease hole is just one more way to get dirt in the bearing. Mix it with grease, it'll never lock up but it ain't good for bearing life either.. I'm neutral on the issue. If you have a hole, grease it. If not, no worries, just crank the oiler and get cutting.
Them old dogs you like Scotty pump some serious oil too. Newer saws are stingy by comparison.once in a while throughout the year (usually when I dress the rails on the bar), I like spray some degreaser or contact cleaner in the nose sprocket, and then pour a little bit of gear oil in the sprocket of my ES bars and spin them manually....That, combined with having my oilers turned up on my saws, seems to keep the sprockets in great condition. I'm like SmokinJ, I've got literally 125+ cord on my 28" ES bar, never had a nose sprocket issue yet......
