I'm working on installing a Jotul 602 into my workshed for occasional heating needs while working on projects.
Going through some other threads, I came into wondering if I am missing a piece! A bottom burn plate.
Here is the thread that got me thinking.
I have a few questions that I wanted to ask the community.
My Jotul 602 Stove
Inside the stove
Stove Manual
Specifically this picture part #35
Question 1 - Am I missing a bottom burn plate or is the bottom of the stove the "burn plate"?
If you are a woodstove Jedi or know this model, Do YOU see anything missing?
I have located a compatible piece (broken link removed) (more than 1/2 what I paid for stove! that's okay though)
Question 2 - Is this stove pipe run okay?
Stove Location:
In a corner on a 4'x4' 18 gauge piece of sheet metal. There are 16 1'x1' paver stones on top of it. Two 5' tall by 4' wide pieces of 18 gauge sheet metal will be mounted on the wall studs in the corner, and I plan on using 1" ceramic or metal spacers to get the heat shield away 1"from the studs. The walls are open. Just studs and wall sheathing.
-If the stove is in this position, I was planning running pipe straight up a total of 3'. Then use a 90 degree elbow turned approx 45-degrees towards the wall and then a 45 degree to go through the wall to the outside. Once outside, a supported T and then just go straight up so I am above the ridge line and use 2 wall mounts to secure on the vertical run. I know the less curves the better, but this is the best idea I can think of so far with having the stove at an angle link in the picture.
Option 2 only requires a stove pipe up and 2 - 90 degree turns to get through the wall and up. Not as aesthetically pleasing but would work.
Stove would see light occasional (tops!) use. Looking for feedback.
Thank you for any help and feedback.
My Jotul 602 Stove
Inside the stove
Stove Manual
Stove Location:
![[Hearth.com] Jotul 602 install [Hearth.com] Jotul 602 install](https://www.hearth.com/talk/data/attachments/225/225756-228996885d30b4965f4392a4705e0ddd.jpg?hash=bTykg_2kSs)
![[Hearth.com] Jotul 602 install [Hearth.com] Jotul 602 install](https://www.hearth.com/talk/data/attachments/225/225961-2c2e9e5cd98be8213c69a0e34f6a4248.jpg?hash=lDKzaQZ4Iq)
![[Hearth.com] Jotul 602 install [Hearth.com] Jotul 602 install](https://www.hearth.com/talk/data/attachments/225/225962-14a65c3c04d07b645d79ee6c4384a1e3.jpg?hash=riH6dIJ7di)
![[Hearth.com] Jotul 602 install [Hearth.com] Jotul 602 install](https://www.hearth.com/talk/data/attachments/225/225995-25ae02b2d1ee0d9ef0276a51aab3f239.jpg?hash=nMzBOmXxjt)
