Jotul 602CB Install
Dustin
613
Western Oregon
Fellas,
A few questions.
I just purchased the 602 today. I'm going to install it in my family room. I have a raised heatform fireplace circa 1955. The chimney will be lined with an SS liner, block off plate, ect.
I would like the stove to sit back inside the fireplace. If I remove the fireplace floor, shown in the photos above I will have more than enough room.
My question is, has anyone ever done this? are there tips and tricks to removing the brick?
I set the stove infront of the fireplace for photo purposes, should I just leave it there and save the trouble?
  • [Hearth.com] Jotul 602CB Install
last pic
I'm wondering if the short leg kit from another Jotul would work on this stove? The hearth will still need extending.
(broken link removed)
If it were me, I think I would go for the "easier" route and just build (or buy) a hearth and leave the stove where it is . . . a benefit would be more radiant heat radiating from the stove through the room vs. radiating from the sides and top into the brick.
I looked into the short leg kit, it was a great idea but wont work for my needs. If I used the short leg kit I could fit the entire stove into that raised fireplace, but, I couldn't use the cook top, as I would have only 5 inches clearance.
I have kicked the idea around of just buying a heart pad......it's starting to seem like a good idea. I would still like to set it back inside a little bit.
Would I lose any heat having it set inside? This stove does not have a blower..
Maybe rotate the stove and use it sideways, putting the long side against the hearth? Then angle the rear vent 45 deg towards the damper opening, and attach to a 45 elbow connected to the liner? The hearthpad would still need to be adequate for safety.
