Hello all. I am installing the Jotul Castine in an old 1979 bowed roof Homette mobile which I am rehabbing. I am ordering the stove pipe (DuraVent DVL) and chimney parts (DuraPlus) from Northline Express. From the stove collar to the roof cap this is what I think I need so far: 6" telescoping DVL stove pipe-chimney adapter-stainless chimney pipe-ceiling support-roof flashing-storm collar-chimney cap with spark guard.
First question: NorthLine says that manufactured homes can only use triple wall for the chimney. Is this true? I can't seem to find any information on this.
Second question: What should the chimney height be above the roof? The Jotul manual has me a little confused:
2.3 Chimney Height
The chimney must be at least 15 ft (4.57 m) high and 3 feet (92 cm) higher than the highest point where it passes through the roof, and at least 2 feet (61 cm) higher than the highest part of the roof or structure that is within 10 feet (3.05 m) of the chimney, measured horizontally. See figure 3.
Chimneys shorter than 15 feet (4.57 m) may not provide adequate draft. Inadequate draft can result in smoke spillage when loading the stove, or when the door is open. Poor draft can also cause back puffing (ignition of gas build-up inside the firebox) and sluggish performance. The minimum height does not, in itself, guarantee proper chimney performance.
Excessive chimney height can promote over-strong draft resulting in extreme stove temperatures and uncontollable fires. Your Jøtul dealer is an expert resource to consult regarding draft issues or other performance-related questions.
Does this mean that the stainless chimney must be 15' tall above my flat roof?
Third question: Would it be smart to go up in pipe diameter to maybe 8"? Is that even possible if I use adapters?
Just for some background info, my father was Norwegian and sold Jotuls here in the US in the 1980s, so I have a very strong attachment to Jotul stoves. Brings back good memories. I will be using the outside air intake kit, floor mount brackets and the proper rated hearth (R 2).
2.3 Chimney Height
