Hi all. It's finally cool enough out that I can fire up the stove. It was installed new this summer on the hearth of an existing masonry fireplace. The stove is piped through flexible single-wall up the chimney.
I've completed the three break-in fires per the manual and I have the first real fire going now. The stove is loaded with 4 small-medium sized splits consisting of a mix of spruce and ash. Moisture level for the wood is around 18% per my meter. The fire has been going for an hour or so now, with a good bed of embers forming. The stove surface temp is reading around 350f in the left-rear corner. The combuster monitor is reading 850f. I have the optional blower installed and set to auto - it kicked on about 30 minutes ago. I have the primary air control set right in the middle. I'm not seeing catalytic combustion. The cat is not glowing, and I'm not seeing flames shooting through the holes in the baffle. The cat activated for a few minutes earlier, but has since gone dark. Is this normal behavior, or is something not right? Thanks.
![[Hearth.com] Jotul F500 v3 Catalytic Activity [Hearth.com] Jotul F500 v3 Catalytic Activity](https://www.hearth.com/talk/data/attachments/300/300831-4ac23ebe0ee2e4987ccfe9f4480d659e.jpg?hash=4azUPCjtm4)
![[Hearth.com] Jotul F500 v3 Catalytic Activity [Hearth.com] Jotul F500 v3 Catalytic Activity](https://www.hearth.com/talk/data/attachments/300/300832-b4ea60949ffb5062fe91d3ad1399c777.jpg?hash=UuE_x4L59A)
