Hi All,
Pardon the newbie question but is it safe to run a key damper on a rear venting wood stove? Quadrafire Cape Cod with a 1.5' rear vent run leading into a T-cleanout and then 24ft of vertical single wall pipe run through a clay lined exterior chimney.
I'm getting really strong draft on cold nights and shorter burn times than expected with 2 year seasoned red oak.
The stove gets nice and hot but I can't control the secondaries with the air shut. If I close things down on a small coal bed after climbing to 450 it can get up to 750 depending on the temp/wind outside.
Thank you!
Thank you!
