King KP60 Draft Light Blink
Tw360797
6
Usa
I have a king kp60 so I went to get it ready for this season and after I've already cleaned, on startup it will barely move the auger and the draft fan will be spinning but it stops feeding an doesn't ignite. I've bypassed all the switches to come to a conclusion that im lost. I've ran it in test mode an everything works fine.
Forgot to mention the draft fan light just blinks constantly
Not familiar with your stove at all but a quick look through the manual seems to indicate a vacuum switch or pressure problem. As others will no doubt ask, have you given the stove a good deep clean?
Eric
Yes I jumped the pressure switch and it done the same thing. Made sure hose was clean as well an switch seems to works when you slightly blow into it
That might point to a bad control card if the light continues to flash.
Thats what im beginning to think now unfortunately, any way to test control board?
Yes, the board can be tested by the board supplier. The best thing would be to get a new card. There's not much you can do on your own.
You can try removing the card and cleaning it, and also inspect it.
Also, I would install whole house surge protection in your panel, and also use a surge outlet for the stove.
