Know of a quiet small box fan?
wahoowad
1,685
Virginia
The room with my woodstove traps much of my heat due to cathedral ceilings and the layout of doorways to the rest of the house. As a result I don't get much flow of heat to keep the rest of the house warm. I do use a ceiling fan in this room and it helps some, but does little to help move the air out of the room.
I found a small box fan helps me quite a bit, my theory being it pushes colder into the warm room which in turn displaces some of the trapped heat which flows back out through the top of the doorway (I have a doorway and a large pass-thru opening to my kitchen). I can feel more heat flowing out through the tops of my doorways when I run the fan (and my heatpump runs less).
My current fan is an el-cheapo from a budget store and quite noisy. Do you know of a quieter box fan? Looking to stay in the same form factor which is no larger than 12x12". What I don't know is if the noise is an unavoidable function of the cfm being pushed or if there is something inherent in a design which can lower the noise level.
(broken image removed)
I use a small Honeywell desk fan that I bought at Lowes. It's actually bigger than a desk fan and I sit it on the floor in our bedroom, so it's pretty quiet.
I use this fan when I need a little air at night. Very, very quiet, it moves quite a bit of air and you can aim the fan to where you want the air to go. I think I bought it at Bed Bath & Beyond, but a quick online search found other options: http://www.frys.com/product/5878073?source=googleps&gclid=CMXf1YbU5LsCFY47MgodzWYAJw It gets my recommendation.
[Hearth.com] Know of a quiet small box fan?
Reactions: Backwoods Savage
The little Vornado fan works very well and is super quiet. You only have to run it at it's lowest speed. We're talking about a 7" diameter fan here so it is very small but works wonders in winter and summer.
