I have a leaking stovepipe. I don't know the specs of the pipe, other than it is shiny steel where it goes through the roof. In a driving northwest rain, sometimes a little water runs down the outside of the shiny part that is inside and drips on the back of the stove. This happens maybe 8-10 times a year. I called the stove installer back a few times, and he tried a few things but never the right thing. Last year I asked a roofing guy to look at it. He reinstalled the flashing around the base, but it still leaked. Then he went up on the roof and played the garden hose around on the flashing for five minutes (no leaks), then tried the vertical seam on the first section of pipe above the flashing. Immediately water started coming in. Of course this seam points northwest. So, it appears likely that the seam is at fault.
I am wondering if there is a way to patch the seam with some sort of high temp sealant. I'd prefer not to have the chimney disassembled. Any thoughts?
Thanks!
Herv
Thanks!
Herv
!!). It is red however so not pleasing to eye but it does work well..... As always, surface prep is key to sealing anything!!
