My pellet stove stopped running and gave the code for POF switch...ordered a new one, installed and same issue. I realized pellets were not filling the burn pot...barely coming out at all. I emptied the hopper to view the auger and it is spinning fine...hmm...watch a little longer and I see a neon green sock! Yes, one of my daughters socks somehow ended up in the hopper. No idea...
I tried to pull the sock out and that is a no go...ended up cutting what I could out of the sock but still stuck in auger.
I have a couple of questions:
1) I hoped the auger would push the sock up the tube and drop it in the pot but it does not appear to be moving...should I just run the auger and see what happens? So far I have ran it four starting sequences where the auger runs continuously for 30 seconds or so.
2) Can I reverse the wiring on the auger motor and have it run backwards pulling the sock back down into the hopper?
3) Remove auger / disassemble stove - I really hope this is not the answer as it looks like a complete pain to remove and I have no idea how to remove the auger.
4) Other?
Thank you for your help...
4) Other?
