Last night we had a few claps of thunder and it got me thinking about pellet stove installs that have venting in an existing chimney using a liner. (Mine is not installed this way)
The chimney is usually one of the highest points on ones house. If you run a metal pipe up the chimney and put a metal weather cap on it, it would seem that there is a pretty good chance for it to take a lightening hit at some point. Stoves are usually grounded through the power cord, at best with a 14 gauge wire back to the mains panel. 14 gauge wire would likely vaporize with a lightening strike through it and the lightening discharge would still seek ground somewhere inside the house.
Has anyone ever had a lightening hit on their stove install that they're aware of and does anyone run from the stove an additional heavy duty ground to a driven rod outside?
Sometimes I tend to think about things too much. This may be one of those instances
