So I bought an Englander 28-4000 wood furnace and am planning on installing it in my basement. My understanding is that it's basically an NC-30 woodstove wrapped in a sheetmetal shell with a blower on the inlet and a hookup for ductwork on the outlet. I have approximately 36 ft of brick chimney(3 stories) with a clay flue that measures about 11"x6.5" inside. There is already a 5"liner for the oil-fired boiler(which is staying). The Englander has a 6" chimney outlet and the manual requires a 6" liner.
I'm pretty sure that I wouldn't get a 6" liner in next to the 5", so my plan was to break out the clay flue to make room. This is proving to be much more difficult than expected. At the top, the flue seems to be right up against the brick, and by-design or not there is mortar bonding the flue to the brick. At the bottom, where there some of the flue was already broken out, there might be 1/2" of space between the flue and the brick. I've broken out the top 5-6ft of flue and I'm very skeptical that I can actually break out the entire thing. I'm also concerned about damaging the brick structure in the process.
So I'm looking for suggestions on how to proceed. Would a 5.5" liner be ok? Is it going to fit? What about 5"? Continue beating on the clay? I'll try to attach pictures of the flue and the tool I made to break it. Thanks for any advice.
![[Hearth.com] liner size issue [Hearth.com] liner size issue](https://www.hearth.com/talk/data/attachments/235/235468-e938c50baa5a51bcc4951906e4b1cf50.jpg?hash=IpClXVYSJ0)
It will be a real project to get a pre-fab installed. Am I unlikely to get another liner (say a 5.5") alongside the 5"er for the oil?
