Hey guys, will try to keep this quick. We purchased a home in 2019 with a Heatilator wood stove insert installed in a mason fireplace. The previous owner had the insert installed in 2017, so 3 years ago now.
We had a chimney sweep come out to sweep and inspect and they found that it was installed incorrectly. The stainless steel flue only extends a few feet out of the insert and then enters the original 1970s terra cotta chimney. No block off plate either, just some sort of insulation filling in the gaps between the stainless liner and the opening to the terra cotta chimney. They informed me I need a stainless flue that goes from the insert, all the way out of the chimney at the roof.
Sweep informed us this is similar to a Direct Connect install that is against manufacturer's approved install, and is dangerous as you cannot get to the creosote that can form between the stainless and terra cotta chimneys.
Anyway, a neighbor let me know that the insert was installed by a large local wood stove dealer that is approved by Heatilator. I contacted them and they confirmed they did install but that no issues were reported with the insert after install.
I just want to confirm, they did install this incorrectly right? They have not gotten back to me since I explained the issues, but I feel like they should fix this issue as it's dangerous and incorrect. However, not sure if I can get anywhere with them as it was with the previous owner AND 3 years ago. To get the stainless flue on my own will be $2.5k so this isn't some simple cheap repair.
I'd appreciate your input here. Do you think they should fix this or no? Have any of you dealt with this before? I'm shocked a reputable dealer would install like this. Thanks for the help.
