Looking for stove parts
DWyman
2
upstate ny
Looking for a type of "backing" that goes between the firebrick and the back of the stove, to keep heat off the walls
It is a Haughs stove, approx 20 yrs old Model#wh7735c5
Can anyone help?
Thank you,
dumfoundedincny
Greetings. This sounds like a wall shield, but the "firebrick" has me confused. Can you provide a bit more detail or describe the problem trying to be solved? Are you looking for something to attach to the wall with spacers to create a 1" air gap behind the panel? This is called a wall shield and is used to reduce clearances to combustible. Or are you looking for something internal in the stove?
Here is an example of a wall shield:
(broken link removed to http://www.northlineexpress.com/itemdesc.asp?ic=5HY-UL3242BL-1C&source=froogle&kw=5HY-UL3242BL-1C)
It is a type of isulation on the inside of the stove, with the fire brick in front of that. This material is about 3/4" thick and made out of some sort of fire proof fiber. This stove was designed to be placed 6" from a wall without any special backing on the walls. Again, it goes inside of the stove itself against the metal then the fire brick in front of the material sorta sandwiched between the back of the stove and the brick. The sides are the same way.
Got it. That sounds like a ceramic insulation blanket material like kaowool. It's sold on eBay but often in quantities. I just checked and there is one seller there that will sell by the square foot. Or call your local stove shops to see if they will sell you some.
