i bought and set up a new lopi endeavor and have been burning it since november. So far i have been less than impressed by its performace, which i find suprising because of all of the positive reviews on this site. Im trying to figure out if its me or the stove. I have about 5' of Dual wall smoke pipe and 20' of class A chimney in an enclosed insulated chase. No matter what i do or what temperatures i try to start throttling the air back it is difficult to acheive a good secondary combustion and maintain it. I have been buring white ash lately and thought maybe it was because the wood was too green so i went to the supermarket and bought some kiln dried wood just to see what it would do. It did perform somewhat better but still not as good as i had hoped. the main thing i have noticed is when the by pass is closed the flames still want to flicker seteadily toward the bypass plate the rear secondaries on the back wall of the fireplace will engage and a few of the ones on the rear secondary bar do as well but the front and middle ones can glow orange and still dont usually produce good secondary combustion this is happening now as i sit here with a 550 degree stovetop which is difficult to achieve without getting the flu gas up to about 800 degrees and then letting it drift down to around the 600 range. i have tried just about every combination of lowering the air at different temps possible so im just wondering is this me or the stove and why do the flames drift back with the bypass closed is there a gasket or something i may be missing i thought they (flames) would come up and over the bypass a little more easily. Does anyone have any suggestions or tips or things i should check for
Pretty typical when someone goes from a smoke dragon to an EPA stove.
