jen said:I am purchasing a new pellet stove. I have had an Enviro Vista Flame for the last 3 winters and loved it. No problems of any kind. My options for a new stove are a Lopi Leyden or an Enviro Meridian. Any thoughts would be helpful. Thanks.
jen said:The meridian and vista flame are basically the same stove and heat 2000 sq ft. The leyden heats 2250 sqft. These two choices are available near me and I can get service on both from supplier.
cuznvin said:jen said:The meridian and vista flame are basically the same stove and heat 2000 sq ft. The leyden heats 2250 sqft. These two choices are available near me and I can get service on both from supplier.
Thee must be a mistake on the Enviro website. It says the Enviro Meridian heats 1200 sq ft...
kykel said:Have you looked at the Enviro M55 Cast FS. Looks similar to the lopi but much easier to maintain. You dont have to shut stove down and clean around burnpot. All the ash falls directly into ash pan. Also is multifuel.
jen said:cuznvin said:jen said:The meridian and vista flame are basically the same stove and heat 2000 sq ft. The leyden heats 2250 sqft. These two choices are available near me and I can get service on both from supplier.
The meridian brochure says heats 2000 sqft. It is the same stove as vista flame which I have now and heats my whole house nicely on setting 2-- 1600 sqft.
cuznvin said:kykel said:Have you looked at the Enviro M55 Cast FS. Looks similar to the lopi but much easier to maintain. You dont have to shut stove down and clean around burnpot. All the ash falls directly into ash pan. Also is multifuel.
I think you need to start selling Enviros..LOL...Good thing you were here though! I wouldnt have even looked at it. Cant wait for Saturday to come so I can go to the dealer!
j-takeman said:Just wondering why your already upgrading the VistaFlame?
Both units your looking at are good ones. I would like to know what prices are. Other things like hopper size and the bells and whisles that usually point to the winner.
One feature the Enviro has the lopi doesn't is the hi/lo that's real handy in the cold weather.
j-takeman said:.
Checkthisout said:j-takeman said:.
I agree that this is a highly useful feature that I wish my stove had.
kykel said:Hi /lo will still burn pellets on low so you would burn more on this setting.( You know its coming vin). The enviro also has auto/off witch will shut down when there is no call for heat. In the auto off position when the stove reaches set temp. it will cycle to low for 30 minutes I believe and at that time if there is no call for heat it will shut down. This will save igniter life if it doesnt have to restart from off repeatedly.
cuznvin said:kykel said:Hi /lo will still burn pellets on low so you would burn more on this setting.( You know its coming vin). The enviro also has auto/off witch will shut down when there is no call for heat. In the auto off position when the stove reaches set temp. it will cycle to low for 30 minutes I believe and at that time if there is no call for heat it will shut down. This will save igniter life if it doesnt have to restart from off repeatedly.
I knew you would have the answer "Enviro King" ;-) Seems like the Enviro will be in my home in a few weeks!! Thanks to you!!
kykel said:cuznvin said:kykel said:Hi /lo will still burn pellets on low so you would burn more on this setting.( You know its coming vin). The enviro also has auto/off witch will shut down when there is no call for heat. In the auto off position when the stove reaches set temp. it will cycle to low for 30 minutes I believe and at that time if there is no call for heat it will shut down. This will save igniter life if it doesnt have to restart from off repeatedly.
dont by it on my recommendation alone. Youve looked at others I assume and when you see the m55 you can make comparisons and see for yourself.
Im am 100 percent satisfied with mine and have not heard anything negative on here about them.
Good luck and keep us posted.
PS I Might have to change my signature to Enviro King. I like it
