Hi new to the forum. I'm having an issue with the exhaust fan. The stove it self is clean out, stack is clean, and I've open the side panel and made sure the exhaust fan and area was clean. So the problem I'm having is the exhaust fan is working during startup but when the main blowers fan turns on the exhaust fan stops or barley runs and the flames get very lazy and black. The stove will continue to run so if I see it happen I can flip the switch to off for a 20 seconds and back on and you can here the stove go back into start up and the exhaust fan comes right back on!! Any idea what's causing this issue?
