Lopi Stove frozen bolts
gutlo
Burning Hunk
200
eastern connecticut
I've had two Lopis. A Yankee (not worth fixing after 17 years of hard use) and a Pioneer which is 10 years old and going strong. Both easy to fix and clean and make plenty of heat.
Just want to give fellow Lopi owners a heads up. The bolts tend to freeze and the heads break off. I think it was the exhaust blower on the Yankee that it first happened, and it just happened on the protrusion that the door cover latch grabs onto. I had to call a handy man to extract the embedded bolt fragment. It had frozen because on the inside it sits in the fire box and it got rusted in place. He remarked that the bolts were of low quality and might not have snapped off a head if they were made of hardened steel. I replaced both with hardened steel.
A word to the wise. Replace any bolt that holds something that you might need to replace to be sure you can do so without breaking off the head.
Reactions: Shane1
A little anti-seize compound on the threads when the fasteners are installed can also be helpful in future removals...
Reactions: DneprDave and bags
