![[Hearth.com] M55 exhaust leak [Hearth.com] M55 exhaust leak](https://www.hearth.com/talk/data/attachments/123/123423-16ea65ead6f080e949f688b4aa5d6b43.jpg?hash=J9CkFowNkR)
Hi again. Ran the stove, M55 steel FS last week at levels 1 and 2. Noted a faint exhaust smell after a few hrs. at level 2. Noted soot on the fan housing at the junction of the rectangular section to the rectangular foot plate (picture). Caulked that, then ran the stove during the Really Cold event. No longer detected odor in the room, but still very faint leak as noted by odor from left most convection air tubes. I found threads discussing slight leaks where I found one, as well as at the exhaust tube mounting. I did my cotton q tip test this am, and suspect I might have a leak between the housing and top of the mounting area. There should be a gasket there, but I suspect it might be leaking. I haven't ruled out the adapter or venting, but the nature of the leak makes me suspect these other areas. New install, duravent pro; adapter, 45 elbow, 3 foot horizontal out the wall to end cap. If I replace the exhaust fan gasket, do I need to disconnect the venting? Thanks for any suggestions. For the poster inquiring about buildup in the burnpot, yup, seems normal.
Also w/ the original convection fan (dealer said enviro won't replace it until/if I get shutdowns), at what levels did the shutdowns occur? Anyone still running this stove w/ the original fan?
