Hi all. Finally installed the M55. It's a dealer demo, original fan (not turbo) and original auger cover (not the adjustable). 4" vent; appliance adapter, 45, straight thru wall 3 ft to cap. Has 3" metal duct outside air connected. I did a test burn outdoors when I brought it home.
Question: should the burning pellets accumulate at the ends of the pot, outside the firebox grate? I started it up and let it run approx. 20 min on heat level 1. Flame looks very good but seems large for the setting. Pellets were nearly contacting the agitator rod at both ends. Should I trim the feed down, or is this normal? I don't know how much fuel should be in the pot. Pellet level as best I could see, was lower in the center of the pot. Would appreciate any info regarding normal levels of pellets in the pot for this stove. It's different from the Bixby, but boy is it quiet!
