Magnetic separators
kuribo
388
SW WI
Anyone use these?
I was thinking of hanging a string of magnets in a removable (magnetic) well inside both my 500 gal propane storage tanks which I could pull from time to time....Planning to use ecm pumps so I thought it might be a good idea!
I put in a Caleffi strainer/magnet combo. Haven't opened it up yet. :)
Would you really snag a lot of magnetic stuff by hanging magnets?
I'm guessing that most of the crude would settle to the bottom in the propane tanks due to loss of velocity. I was thinking of something along the lines of a magnetic drain plug which stuck up inside the tank a ways inside a removable well....maybe hard to get it out without losing a lot of water....Hmmmm...
What about getting an actual magnetic drain plug of a fairly large size, then adapting it to thread into a threaded T. You could put the T inline just upstream of a pump, with valves on each side. Close the valves, unscrew the plug & check/clean, screw back in & unvalve.
The allure of doing it in the storage tank of course is that things would naturally settle to the bottom....but I think the drain plug in a tee idea would probably offer some protection as well...
Or thread a magnetic drain plug into a Y strainer in the same fashion as maple1 said.
TS
I have two vertical 500 gal propane tanks for storage.The return pipe is right in the bottom of the tank.The bottom now slopes towards the return.I have a valve right at the lowest point on a t which the return plumbs into.
When i flushed my system at startup i found a lot of sediments at the valves.I flushed the system till no more stuff came out of the valves.95% of the plumbing in my system was reused pipe and fittings all copper except for fittings on the tanks and boiler.
One thing i do every fall before i start any of the pumps is to check the bottom valves for accumulated stuff both from use because the valves are the lowest point,and from settling out of the tanks when it's not in use.So far i have never found anymore stuff in the valves.I also have a y strainer right before my plate heat ex-changer,it has also remained clean.
I don't worry about stuff in the system as much anymore.
How do you know? :) But seriously, have to drained it or whatever, and looked at it, and after how long a period of time? (I haven't yet.)
I had a bunch of Heat Way rubber radiant tubing in my system from back in 1992 when the house was built. Subject to a class action suit - another story. It allowed oxygen to enter the system. I've been replacing this with PEX as I remodel. Still have about 50' in the system (bathroom floor). The Caleffi Dirtmags would show a puff of black iron oxide particulate when I hit the drain (into a bucket) after a month or so. Now that the oxygen is mostly gone from my system I see little captured iron. Faulty make-up water systems can also add oxygen creating the problem.
I have copper distribution and a steel tank and boiler. Perhaps I will check it soon; it doesn't sound like a big deal. As an aside, I got the insulating jacket for the Dirtmag, which looks real good, and should have a payback of 1,000 years.
We are starting to get some good feedback and pictures from magnetic separators at work. This was installed on a large mechanical system north of Chicago. the installer has flushed the sep 3 times now.
The magnets work best if they are in the fluid stream. The separators have a media inside and also provide a low velocity zone to slow the fluid as it passes thru.
