Making a nozzle for the biomass 60
woodsmaster
2,896
N.W. Ohio
Made a form to cast a nozzle for my biomass 60. Waiting on my refractory, cement and needles to show up now. I still gotta make forms for the other parts.. was just going to buy the parts but was unable to find them. I think I can use some 5 gallon buckets as part of the forms for the curved parts.. hope everyone is in good shape to stay warm this winter !
Reactions: Burnin Since 1991
Forgot to post a picture of the form I guess
[Hearth.com] Making a nozzle for the biomass 60
Another one. Made from aluminum coil stock and some scrap wood.
this homemade nozzle is for my econoburn 100 . oiled the form (vegetable oil) and used foam for the nozzle part of the mold to make it easily removable. 1st try i used plywood and had a hard time getting the brick out. the air inlets are PVC . Bruce
  • [Hearth.com] Making a nozzle for the biomass 60
Reactions: woodsmaster
Well, I made the nozzle and I learned the hard way that I should’ve used foam for the middle. took me a little while to get it out. I used some plastic 1/2 well pipe for part of my holes and I use some metal pipe on a few. The metal pipe didn’t come out near as easy as the plastic did. I also used vegetable oil on everything I failed miserably at my first attempt at the bottom blocks. I think I might just buy some fire brick and try and make it work for the bottom.
These come out good
When you are ready to mix your refractory cement, if it comes in a bucket or bag it is always best to mix the hole bag or bucket at one time. On the refractory bag it will tell you how much water to use, this is very important. I mixed a 1/2 bucket of refractory and the refractory did not turn out good. On my wood forms I wrapped the wood in plastic to have a nice smooth finish. Good luck
