Manual needed
CO361
1
EHT, NJ
I am looking for a manual or installation information for a Birmingham stove model 516U-DG. I was giving the stove and I’m attempting to use it in a garage which is a metal building but I am unable to figure out how to safety use this stove without a manual.
Is this an old stove? If so, no manual is likely to show up. Post some pictures.
I am looking or a copy of a manual for an Atlanta stoveworks 15-36 or some information on the door ender the oven door- ours is missing
You can make a clean out door from any steel plate. Do not use the stove with wood missing the cover. It will allow indoor air to rush into the exhaust cooling the chimney flue causing creosote.
To clean under and around oven from the missing door you need a scraper on a long rod, like wire handle with a 90* scraper on the end.
We don’t know the dimensions for the door- can anybody help? Or maybe someone has a picture of the stove with the door?
I believe it is illegal to have a wood (solid fuel) appliance in a space that stores gasoline etc. So if you put a stove in there, get out your car, lawnmower, Jerry cans etc.
Measure the opening height, 2 inch flat stock should work. 1/4 inch thick mild A-36 steel. To get the correct radius I cold work on a piece of railroad rail.
To make your own cast parts is much more involved making a wood pattern of the original part and have a foundry cast it for you with iron if you don’t have use of a forge. A steel replacement cover is fine for a user stove compared to an all original collectible.
