If I add hot water tank valves, to the loop and the lower one would have a pressure relief attached, from there, the hot line 3/4" Pex runs to a 1 to 2 manifold where it splits off and then runs two (1/2" Pex) lines to 14 fin cast iron radiators, the return (cold side) runs to a second manifold where it goes from 2 (1/2" Pex) lines into 1 (3/4" Pex). From here, the cold side has a Tee fitting leading to an expansion tank and the other side continues through a circulation pump, it is then pumped back up to the top side of the loop.
My question is, do you see a concern with pressure in this system? Would the volume of water held be enough to prevent boiling or would you also add a holding tank or chiller line into the mix?
