All,
I have scoured the forums for quote some time looking for relevant information for my issue/question but have mostly come up empty. Due to my location, there aren’t very many stores/vendors around, and the one fireplace specialist/sweep I reached out to about these questions has basically ghosted me.
Background:
I have an old masonry fireplace which was inspected last year (the report is attached). I’m not interested in repairing the terracotta but I am VERY interested in replacing/upgrading the setup to a newer catalytic style stove/insert. From what I have gathered, I will need a liner (insulated), a new cap, and possibly some demo of the old damper. Additionally, I understand that regardless of the ‘demo’ decision, i will need to either go with an oval liner, or perhaps a transitional piece near the quick connect/transition.
My intent:
The house is rather large 3k sq/ft and based on what I’ve read on here, the internet, and the manufacturer's claims, there’s no stove that will heat the entire house. Either way… last year, using the old insert (another fireplace in the house), we were able to significantly reduce our HVAC bill, to almost zero. Add to that the ‘winter bombs’ and the increasingly unpredictable weather and suffice to say, I just want something better.
What I REALLY want is an actual stove but based on the dimensions and what I have seen ‘most’ people go with, an insert would be much better suited for this scenario. In fact, it looks like the Regency CI2700/HI500-1 Pro series would slip perfectly right in there. However, as this is a B.I.F.L sort of purchase, I want to make sure I don’t get something that, in a year or 2, I will regret and wish I ‘went larger’. That’s where you guys hopefully come in. =)
Questions:
I hope this isn’t too much and I tried to organize everything as best I can. It’s a big purchase and something I only want to do once so I figured I’d ask the experts first!
Thanks in advance, have a happy Labor Day.
Matt
Imgur Link to photos
Background:
My intent:
Questions:
- Is the difference between an insert and a stove, performance wise, noticeable? And if so, is there a measurable difference which would be worth the trouble to make the switch given my situation?
- Is it reasonably possible, given the dimensions of this masonry fireplace, to make a stove work or is the juice not worth the squeeze?
- Is an offset realistic in this scenario? And if one is used on say a Regency 5200, would there be any additional modifications needed to the liner? I wasn’t able to find the Installation manual for the 5200 (https://regency-fire.com/en/Owners/Service-Maintenance/Manuals) but I was able to find it for the 3500 and it states ‘minimum vertical 36” before any offset. This essentially kills this idea, correct?
- Code compliance options if DIY? I plan on doing this myself and if done this way, based on what I have read on this forum, there are some code compliance AND insurance considerations which need to be taken into consideration. Assuming these vary based on locality and insurance company but generally speaking… Are these a PITA do get done/scheduled properly?
- Would you remove the Damper Assembly or cut a hole into the existing metal (assume this is cast iron based on the weight and feel of it)? Possible third option, go with an oval liner?
- Based on the architectural drawings and photos, my clearances should be fine for a 6”/8” liner, right? Or do I need more info to confirm this?
- Existing chimney is ~16.5’ tall and located at the direct center of the house. Is this okay for drafting/pull of a stove/insert, or should this be something I look further in to?
- As far as online liner suppliers go, RockfordChimney and Chimneylinerdepot seem to be the most suggested. However, I’m a bit confused on which type/style liner would be best. Based on what I have researched, smooth walled would be optimal. However, what is the difference between 316, 316L, and 316Ti? To make matters worse, chimneyLinerDepot has a 316ti SS Liner. I would just like to know what order to put them in and what the ‘BEST’ one is. Would something like this work? https://www.northlineexpress.com/6-...wall-liner-kit-with-tee-sm625k-tee-19713.html
- Based on the ~16’, I would want to purchase a 20’ liner, right?
Matt
