I am brand new to wood stove inserts and fireplaces, in general.
I removed this Matherly Heat Saver wood stove insert from a home built in the 1950s. There is a grill with a vent above the fireplace where the insert used to be. It seems but I can't tell for sure, that the vent is part of the metal firebox and the whole thing got bricked in after it was installed. There is also a light switch to the left of the hearth that turns on fan or a blower.
1. How can I remove the interior vent over the fireplace? I'd like to put a mantel in and may just leave it as a fireplace without a new insert. I'm comfortable removing brick but am not with disassembling something connnected to the metal firebox. If I have to hire someone, I'm not assuming they will know what to do since it's an older installation.
2. Can I reduce the hearth width? I'd like to make it closer in size to the actual fireplace. It runs across 3/4 of the wall. There are slatted vents in the hearth on either side of the fireplace.
Thanks for any insights and guidance!
