I had a new Max caddy (wood/oil) furnace installed in my house over the summer. Since I began to use it last week, I have had an odor of smoke in the house and today my CO alarm activated. I had around 75ppm of CO throughout my house. After I ventilated the house, I held the CO meted directly up to the air vents in the house and had about 20ppm of CO blowing out. When I use the oil backup there is no odor and no CO. What could be the problem and who do I turn to for repairs????? The unit is vented with 7" SS liner into the existing 9"x12" masonry flue. There are four flues side by side that terminate above the roof, could a downdraft from one of the other flues be drawing the smoke back down into the house? Could it be a draft issue and I should reline the masonry chimney with 7" flex pipe? Could there be a problem in the wood fire chamber that is allowing smoke to get into the air ducts? Thank you and please give me some advice if you can.
![[Hearth.com] Max Caddy problem...HELP!!! [Hearth.com] Max Caddy problem...HELP!!!](https://www.hearth.com/talk/data/attachments/142/142006-baccfe4338650f57ef7d3fc64c7154af.jpg?hash=S-PG8N-M1f)
![[Hearth.com] Max Caddy problem...HELP!!! [Hearth.com] Max Caddy problem...HELP!!!](https://www.hearth.com/talk/data/attachments/142/142007-a4a2b13589f362761d4d0312e30f7534.jpg?hash=iYn7FSJUz7)
![[Hearth.com] Max Caddy problem...HELP!!! [Hearth.com] Max Caddy problem...HELP!!!](https://www.hearth.com/talk/data/attachments/142/142008-b490936d4160482ed8c75f918bb79fa0.jpg?hash=5u5oj39EQA)
![[Hearth.com] Max Caddy problem...HELP!!! [Hearth.com] Max Caddy problem...HELP!!!](https://www.hearth.com/talk/data/attachments/142/142009-e0116c53a149b2573592c0d59744af19.jpg?hash=ZDhhaO7v-p)
![[Hearth.com] Max Caddy problem...HELP!!! [Hearth.com] Max Caddy problem...HELP!!!](https://www.hearth.com/talk/data/attachments/142/142010-b0cfe05338ff686fd420ab96b03af586.jpg?hash=wAKXXpFb3o)
