Hi all,
We have an old house (1930's) and we are replacing the existing fireplace which dates to 1977. I have no idea if there was a fireplace here prior to 1977 or if it was just added then. We've decided to re-do it and upon pulling back the 70's marble and lots of brick, we exposed this metal (pre-fab) fire box. The company we've purchased our new wood burning insert from has suggested we remove this metal firebox. Two q's:
a. I'm a tad concerned my chimney will collapse (I have no reason to believe it will, just seems like perhaps the insert is supporting it!). The fireplace company says it won't, that there is a header in there that is supporting the chimney and that the metal box just slides out. Is that right?
The bricks on top of the metal firebox are actually behind the lathe, which means they must have built the firebox from the exterior in, as there is a newer (1977) chimney build on the exterior of the house. I've attached pics, the chimney related to this is the newer, front one.
Any thoughts would be appreciated!
![[Hearth.com] Metal firebox removal help [Hearth.com] Metal firebox removal help](https://www.hearth.com/talk/data/attachments/248/248587-7751d091cb92e05ed17c655d60e43ac1.jpg?hash=sOJcRpyqGv)
