![[Hearth.com] MH Puzzling Together [Hearth.com] MH Puzzling Together](https://www.hearth.com/talk/data/attachments/183/183535-ccedf11b5c588e399814fe08dbb1b6d6.jpg?hash=-hYbfb9H4i)
Looks good. Can't wait to see how it performs.
Awesome giant heater.
When you say you got your plans from the MHA, did you adapt a general design from their webpage or did you work with a stove mason to come up with a design for your particular setup? It almost sounds like you changed things a lot on the fly...
Knowing that my setup required something a little different (smallest reasonable footprint, fairly low heat output), I had a stove mason design the thing for me--StoveMaster/Alex Chernov. It only cost $200 for how simple I kept it, plus gave me a very detailed plan. With the facing & everything it will come out to around 21x21 inches & 5.5 ft tall; it has an Austrian Ecco firebox with a bell on top as the heat exchange--the contraflow designs take up a bit more floor space.
. And after this, I ran a few more fires through it just for the fun of it. It would stay warm for a long time even outside. I would open the door and there would be bugs hanging out inside in order to stay warm (early fall).![[Hearth.com] MH Puzzling Together [Hearth.com] MH Puzzling Together](https://www.hearth.com/talk/data/attachments/188/188772-fe9143f0f45860000c009e4d84160fd3.jpg?hash=BhmU2Mom5L)
![[Hearth.com] MH Puzzling Together [Hearth.com] MH Puzzling Together](https://www.hearth.com/talk/data/attachments/234/234105-1a543ac42ab809ce5781bbf3003e331f.jpg?hash=OSzgShdLz-)
Most chimney pipe manufacturers make a transition plate for just this purpose. Search on 'chimney transition plate'
https://www.rockfordchimneysupply.com/rock-vent-transition-plate.php
I like the screen, but can it be removed?I fired it up with progressively larger loads of firewood in order to dry out the mortarView attachment 188742 . And after this, I ran a few more fires through it just for the fun of it. It would stay warm for a long time even outside. I would open the door and there would be bugs hanging out inside in order to stay warm (early fall).
![[Hearth.com] MH Puzzling Together [Hearth.com] MH Puzzling Together](https://www.hearth.com/talk/data/attachments/254/254271-45d55bd834e9dfddf7dd3f976560defb.jpg?hash=tDiCpk2FgO)
![[Hearth.com] MH Puzzling Together [Hearth.com] MH Puzzling Together](https://www.hearth.com/talk/data/attachments/254/254274-8280468dec6bb489015291bc9c976466.jpg?hash=QJJmXFuJKu)
![[Hearth.com] MH Puzzling Together [Hearth.com] MH Puzzling Together](https://www.hearth.com/talk/data/attachments/254/254276-cd008f35400caa9eb4ec5f32f7224abd.jpg?hash=16cG-rLQP2)
![[Hearth.com] MH Puzzling Together [Hearth.com] MH Puzzling Together](https://www.hearth.com/talk/data/attachments/254/254504-4b4daa3735130f83fda6ff8492a9811c.jpg?hash=oiOBTBzKVW)
![[Hearth.com] MH Puzzling Together [Hearth.com] MH Puzzling Together](https://www.hearth.com/talk/data/attachments/254/254503-c2a127adf9194cb5362ed22ccfa29ab3.jpg?hash=PBjCQ8ecNH)
![[Hearth.com] MH Puzzling Together [Hearth.com] MH Puzzling Together](https://www.hearth.com/talk/data/attachments/254/254502-156f26bf4410919f6ea3840351e6dfee.jpg?hash=Io9O7N3mv5)
That is good to know. I think this is my building inspector's first masonry heater, so he said, '..at least a 2" gap' ( just to be safe I guess).My heater goes right up to a beam. The beam is still a couple feet from the nearest heat channel and the stones that touch the beam never get hotter than the mid 80s.
