Hello everyone. My name is Butch R. and I'm grateful for your help. My dilemma is I'm renovating the basement and relocating the wood stove and I'm getting conflicting information from my local Fireplace/Swimming Pool dealer and resources on the internet. To keep my clearances as close as possible to the wall, against the studded wall in my walk-out basement I have been told to double layer 1/2" thick Micore for a total of 1" fastened to metal studs. Also we took the liberty to cut 1" width off of the existing 6" studs that comprised the walk-out side of the basement to provide the 1" gap behind the Micore to meet "code, expectations" from any flammable material . I apologize in advance for not searching the data base for an answer but I was led to believe that porcelain tile will readily adhere to Micore by the people I have been dealing with. Searching the WWW I have found the opposite. The wall behind the wood stove that is being prepped and tiled measures 4' x 8' on a concrete floor. It is being prepped and tiled from the floor to the ceiling. The width of the wall exceeds the recommended width according to the powers that be.
The stove is a Warnock Hersey/Dutch West Model #2461. Clearance from back of stove is 24". Clearance from back of flue is19". It exhausts from the back. With the above improvements I've been told I can achieve 10" clearances from the wall.
My main question is will tile adhere to Micore? if not please advise. The wall behind the stove is metal studded on 13" centers both horizontally and vertically and offset both ways so I can overlap the seams on the Micore and attach to studs. I am already 1/2" raised above the surrounding sheetrock so if I have to put some hardy backer, concrete board over the micore for the tile to adhere to so be it. I thought I had this thought thru but I admit I'm a dummy.
Also I have ordered the heat shield for the stove which is supposed to be a double layer metal shield with air gap. Any advice with requirements or advice on getting tile to adhere to the wall would be appreciated. Thank you!
