Is anyone aware of a wired milli-volt thermostat with a wide temperature variance. I have a Breckwell pellet stove that allows a room thermostat to be wire into the control panel. The control panel has three settings for operation :
1. Manual -- Just a simple on/off button
2. Hi/Low -- when the thermostat calls for heat, the stove runs on a higher setting and when the thermostat is satisfied, the stove runs at a lower level until more heat is needed.
3. On/Off -- when the thermostat calls for heat, the stove turns on. When the thermostat is satisfied, the stove shuts down.
The On/Off setting is used in early fall and late spring when all you need is a short run time to take the chill out. My problem is the cycle time is too short. I am looking for a thermostat that will heat to a couple of degrees higher than the setting before shutting down and then wait for the temp to drop a couple of degrees below the setting before re-starting. The thermostats I've tried have such a tight variance, the stove is continuously starting and stopping, resulting in significant wear and tear on the igniter.
