I'm trying to figure out different ways to set up my new EKO boiler and heat storage without the need for an expensive expansion tank. I only have one zone in the house (water to air exchanger), so to keep things simple I plan for the boiler, storage tank and zone loop to use the same water.
One option I am considering is to run a line from the storage tank to a small tank which would be located at the highest point in my system and have it open to atmosphere. So when the system water expands/contracts, the water level in this tank will rise and fall. Based on my system volume of approximately 500 gallons, a small 20 gallon tank should be sufficient to handle the expansion volume of the system water, and I would just leave a plug at the top of this tank open. Running a line to this location in my house is very easy, so there is no problem from an installation standpoint.
One concern I have with this approach is whether I will be maintaining enough pressure in the boiler. The expansion tank will be located about 15 feet above the boiler, which would give me a little more than 5 psi in the boiler. I suspect the water in close contact with the boiler exchange tubes may get close to the boiling point, so I'm wondering if 5 psi is enough to minimize the formation of bubbles at the steel/water interface, which would theoretically reduce heat transfer efficiency. Anyone with comments on this issue, or on this approach to a low pressure semi-closed system? In terms of minimum pressure on the inlet side of the circulating pump, 5psi is more than sufficient based on the specs for most pumps. I would also plan to monitor water pH etc. to make sure it minimizes corrosion.
