i know about the green mountain 80 ,any thoughts on it?.are there any other modern stoves with 8" pipe?
The Regency 5200 is a good 8" stove. Looks better than the king. And is reliable.ya but king is not the most attractive stove out there lol
They are for serious wood burners. Those people understand..I realize beauty is in the eye of the beholder but I wonder why BK doesn't make an effort to make better looking stoves. We all know they work well but my goodness are they ugly. Not that they are hurting for sales but I bet they lose some because of appearance.
I'm sorry but that's not a valid reason to make it ugly. I personally wouldn't pick a worse stove due to looks. I just think it's strange there are so many beautiful stoves out there and the folks that make the consensus biggest baddest one of them all make it pedestrian looking. To each their own!They are for serious wood burners. Those people understand..
I tried my best to decipher that. If looks is most important then good luck to you. Green mountain sucks overall is my professional opinion. Bk is top dog, the regency 5400, is next, nothing else… looks doesn’t have much play in the big heater/efficiency category. If looks are most important, then you have more options with 6” stoves.I'm sorry but that's not a valid reason to make it ugly. I personally wouldn't pick a worse stove due to looks. I just think it's strange there are so many beautiful stoves out there and the folks that make the consensus biggest baddest one of them all make it pedestrian looking. To each their own!
I'm not the OP. Just a bystander commenting on the looks of the King. Never said it wasn't the best, I'd get the King too if I were in the market for a big 8" stove. I'm just a guy wondering why the best can't look awesome too.I tried my best to decipher that. If looks is most important then good luck to you. Green mountain sucks overall is my professional opinion. Bk is top dog, the regency 5400, is next, nothing else… looks doesn’t have much play in the big heater/efficiency category. If looks are most important, then you have more options with 6” stoves.
If you need what Blaze kings are good at yes they are the best. But there are tons of 24/7 burners that won't use their low and slow very much at all. Which means there are many stoves that do competeHonestly, if you intend to burn 24/7, nothing can compete with a Blaze King. Some have better looks, just like a dodge, but don’t be fooled, they aren’t the same!
I’m pretty sure everyone on here has spring and fall. It’s pretty awesome to be able to heat in the shoulder seasons with such ease. Some don’t bother and I get that.If you need what Blaze kings are good at yes they are the best. But there are tons of 24/7 burners that won't use their low and slow very much at all. Which means there are many stoves that do compete
Yes but if you have short shoulder seasons and you need high btus the rest of the heating season a bk is not going to be the best. It may be best for you but blanket statements like you made really aren't accurateI’m pretty sure everyone on here has spring and fall. It’s pretty awesome to be able to heat in the shoulder seasons with such ease. Some don’t bother and I get that.
I can’t see any instance where a BK wouldn’t be good, then excel in other situations. You don’t like them, you’ve Made that very clear the last few years you’ve been around here. That’s ok, we’ve all got our favorites.Yes but if you have short shoulder seasons and you need high btus the rest of the heating season a bk is not going to be the best. It may be best for you but blanket statements like you made really aren't accurate
Or they have a more efficient, cleaner, and possibly less expensive alternative like a modern heat pump. In that case, running the stove when it's mild outside doesn't make sense or cents. And then there is the weather variable. We ran on the heat pump for most of December. That was a first, but 2023 was the warmest year on record.I’m pretty sure everyone on here has spring and fall. It’s pretty awesome to be able to heat in the shoulder seasons with such ease. Some don’t bother and I get that.
Well said. I wouldn’t have a heat pump due to cost of electricity in my area. Lp gas is affordable here though. The ashford would be very comparable to your PE from my experience.Or they have a more efficient, cleaner, and possibly less expensive alternative like a modern heat pump. In that case, running the stove when it's mild outside doesn't make sense or cents. And then there is the weather variable. We ran on the heat pump for most of December. That was a first, but 2023 was the warmest year on record.
That said, the past few days have made up for it. In this case the stove is being pushed for heat in which case, the extended burntime of the BK diminishes notably. In this scenario, it doesn't make sense for us. My preference is for a well-built, KISS designed, non-cat. But then again, if it weren't for the heat pump, I might have an Ashford, but it would be working its tail off right now. When it drops below 20º we need high BTU output due to the heat losses of the house.
In general, yes, though the Alderlea has a higher top end than the Ashford and we are using that today.Well said. I wouldn’t have a heat pump due to cost of electricity in my area. Lp gas is affordable here though. The ashford would be very comparable to your PE from my experience.
As you know. Published btus are hard to judge a stove by. The ashford will rock if it’s needed.In general, yes, though the Alderlea has a higher top end than the Ashford and we are using that today.
We've been riding the heat pump too. All that cold is coming my way I'm bringing in a lot of maple for hot fast fires this week and oak for overnight. Bark for coal burn downs. It's going to be a serious week of full power 24/7 burning. Possibly even some backup heat overnight.Or they have a more efficient, cleaner, and possibly less expensive alternative like a modern heat pump. In that case, running the stove when it's mild outside doesn't make sense or cents. And then there is the weather variable. We ran on the heat pump for most of December. That was a first, but 2023 was the warmest year on record.
I love my F350 7.3L 6 speed manual. My Stihl 036 Pro. I don't work for these guys but they all get the job done better (in my opinion) that other trucks, saws that I have owned.I detect some commercial bias. 😉
JK we love you bkvp!
