I have a circa late 1990s Moen "monicello" type shower faucets, 2 distinct hot/cold lever in my shower. I recently had to replace the "stem extender's in the copper shower diverter/fitting that is threaded into the wall behind my shower enclosure.  The nub at the end that actually moves the valve broke off such that the lever was spinning forever.  But now I noticed it seems the valve itself is loose, the lever pushes the valve around and around and although the water does shut off, it doesn't have a positive lock anymore.   I know about the cartridge valve removal tool that Moen sells that is cylindrical and allows you to replace the valve inside the copper fitting... But I was able to use my needlenose pliers to try to tighten (clockwise) the outer valve holder ring thing.  Still doesn't seem to tighten the valve. Is there anything behind the valve that might have broken which might be fixed with a new valve or what?
I believe my father had the same problem and a plumber put a kludge in it by using a screw and basically screwing into the faucet such that the handle will stop at the screw. Obviously, the screw is visible but my father didn't want to replace the thing...
jay
jay
