Looking to buy one and they range from $550 down to $11. Please give me your opinion on what I should be looking for?
Change the batteries to a better set it works far better that way.I have the Harbour Fright meter. I think it works okay, but having never used any other (more $$) meter, I have nothing to compare it. You have to push the probes in to the wood as far as you can to get a good reading, but it was cheap and as far as I can tell, accurate enough.
Peace,
- Sequoia
Cause everyone else has one so I wanted one too.at the risk of becoming known as a total curmudgeon ..... what's the point of MMs for firewood ? It's either ready ,or it isn't . If Your MM says "nope ,it ain't ready " then what ? Jeez guys , just stack it for 2-3 years and it'll be good .
Curmudgeon rant over
Because not everyone has the luxury of a full on 2 year in advance supply for a number of reasons...better to burn safe than burn sorry.....seriously, it is just to make sure as a newer burner that the look and feel of ready wood is really ready...I started this thread wondering why some MM were 550 and some were 11bucks....so far no one has given that answer and so for under a fin I can just make sure the wood going into the stove is good to go at least until I get a better feel for things.at the risk of becoming known as a total curmudgeon ..... what's the point of MMs for firewood ? It's either ready ,or it isn't . If Your MM says "nope ,it ain't ready " then what ? Jeez guys , just stack it for 2-3 years and it'll be good .
So,does the MM make wood "season " faster ? To have properly burning wood is all about planning beforehand . If You CSS your wood with enough time for it to dry properly,a MM is not needed . If You don't , the MM will tell you to wait until the wood is ready to burn .Because not everyone has the luxury of a full on 2 year in advance supply for a number of reasons...better to burn safe than burn sorry.....seriously, it is just to make sure as a newer burner that the look and feel of ready wood is really ready...I started this thread wondering why some MM were 550 and some were 11bucks....so far no one has given that answer and so for under a fin I can just make sure the wood going into the stove is good to go at least until I get a better feel for things.
Ok curmudgeon. All I was doing is asking a for a little bit of advice from people that had experience. I am sorry I am not an expert like you, it takes time you know. Your rant against my question is not helpful here, it is not wanted here, when you see a question you do not like because you think we are idiots, you must know that you have the option not to answer it...just skip by it and chalk it up to an idiot asking an idiotic question....someone as experienced as you are must be able to exert a bit of self control by now I would think?!So,does the MM make wood "season " faster ? To have properly burning wood is all about planning beforehand . If You CSS your wood with enough time for it to dry properly,a MM is not needed . If You don't , the MM will tell you to wait until the wood is ready to burn .
In short , work towards having the luxury of having decent wood to burn .
Or a felt tip penYou know whatr I'm gonna say: "The best device for checking the moisture content of your firewood is a multi-year calendar."
a felt tip pen
Your point being ? I didn't call you a name ,or insult you . If You took offense , I publicly apologize . Feel better ?Ok curmudgeon. All I was doing is asking a for a little bit of advice from people that had experience. I am sorry I am not an expert like you, it takes time you know. Your rant against my question is not helpful here, it is not wanted here, when you see a question you do not like because you think we are idiots, you must know that you have the option not to answer it...just skip by it and chalk it up to an idiot asking an idiotic question....someone as experienced as you are must be able to exert a bit of self control by now I would think?!
All this talk about moisture meter forced my hand! This morning at my local hardware store I had to buy one, a General MM1E. The two ranges are 7-15% and 16-35%. It uses a 10 LED display.
Most of my stacks are between 12 to 15%. Some touched 11%. A real impulse purchase, thanks guys!
No I do not...every once in a while someone comes across with a holier than thou attitude. That is just not helpful. This site has been awesome and 99.9% of the posters here are truly well meaning people here to help....guess you are just in a bad mood or in that .1%Your point being ? I didn't call you a name ,or insult you . If You took offense , I publicly apologize . Feel better ?
Thank youThe moisture meter is good for people like me that are in their first year of burning with 2 year stacked wood available, some of which is oak and some of which is locust. Threw the locust in the furnace, and it burned like CRAP. Actually, buffalo chips would have burned better than it, so strike that. It burned horribly, if at all. A moisture meter later, I found out that locust split and stacked since August 2011 still had 37% moisture content. The oak from the same time period had 24% moisture. So, oak it is now. Ran out of my poplar and other crap wood, so I need to burn something that didn't dry in 6 months to a year.
If/when I get 3+ years ahead, I will be more than happy to use the moisture meter for target practice.
Thank you
My Boss is a curmudgeonat the risk of becoming known as a total curmudgeon ..... what's the point of MMs for firewood ? It's either ready ,or it isn't . If Your MM says "nope ,it ain't ready " then what ? Jeez guys , just stack it for 2-3 years and it'll be good .
Don, I'm not trying to be arrogant . Nor do I think that I'm in any way superior to you . I was just trying to say that firewood takes TIME to season . a MM is useless in that regard .Season Your wood for 2 -3 years ,and you'll be happy ,so will your flue .If I rubbed You the wrong way , I'm sorry . The internet makes it hard to come across the way we intend at times .No I do not...every once in a while someone comes across with a holier than thou attitude. That is just not helpful. This site has been awesome and 99.9% of the posters here are truly well meaning people here to help....guess you are just in a bad mood or in that .1%
This last apology seemed more sincere than the first attempt...I am good to go.Yeah, but before you get on Nixon too much, he has been really helpful on here a lot of times. So, both of you go to your corners and wait until I say you can come back to play. lol
