OK, for only the second time, I have the unit out of the fireplace by myself to clean in the back. It took forever, but I finally got the "fines box" cleared out (I see the auger back there, so that's where it is, is it OK that there are still some pellets in the auger?).
(A) I pulled out the unit about 16". To clean the flue with a section brush, does one clean the flue with the unit out from the wall , or once the unit is back in place (the instructional DVD seems to show the latter)? There's very little room back there to manipulate those sections without running into the back of the unit. I'd see a straighter "path" once the unit is back in space.
(B) Yet again, I'm confronting a unit that just hums when turned on, instead of running. Last year, after a topic here, I caved in and had a service call, which I'd like to avoid. The recommendation to use a test cord on the combustion fan is beyond me, I'd been staring at this thing trying to figure out how to access the connectors with the fan still in place, not happening. After really cleaning around the fan, it spins freely and I risked turning the fan on while the fan cover and all the over removable front-end panels/covers were off; no change. Now that the unit is out, the fines box clear, and the two distribution fans seems to spin freely, is it "safe" to plug the unit back in while that unit is still out of the fireplace, to see if it will spin?
? I have not looked on-line for a tutorial. Perhaps there is a specified torque setting for the three bolts.
) OK, part list in the back, the blower # does end in 08639 so that's great, the fan install says 5" and part # 3-20-50221.
