The Morso 2110 was installed last week, my only complaint so far is the manual, very simple, "The initial fire should be small, so that the stove paint can cure and the main plates of the stove can settle into position. Some fumes will be given off by the paint. Ventilate the room during this phase." I was looking for more specifics on temps, the flames coming off the top baffles, etc. Here is what I did based on what I read on Hearth.com:
First fire, Friday nigth, burned 2 fat wood sticks and 4 -6 pieces of kindling (bought a bag of sticks at Lowe's), did not have a temp guage. Pretty much left air control all the way to the left, which I figured out means open - manual just said move lever downward, which makes no sense since the lever is on the right of stove and moves from right to left and left to right. No smell of paint.
2nd fire, Sat morning, (went to dealer and got a temp guage for top of stove - magnet, but it doesn't stick to pipe not sure why) burned 2 fat wood sticks, several pieces of kindling and got it to 200 degrees. Moved lever to the middle. Then let it go cold. Made another small fire that night with one piece of split wood, reached 200 and let it go out. Very little paint smell
3rd fire, Sunday afternoon, this is when the fun began, started with fat wood and kindling, then 2 -3 splits, air control full, got over 300 degrees then moved lever to right (closing air), then fire went down around the wood, saw flames on coals and bottom of wood and then flames shot out from the top baffles for several minutes then stopped. It looked weird to have no flame in center of stove, only under wood and from the top. Finally started to really smell the paint fumes.
4th fire, Monday night, started fire, let it get to 450, with more paint smell. As I closed the air supply, the flames would come out top, but only for a few minutes.
5th fire Tuesday, last night, started fire, got it over 550, then panicked and closed air to bring temp down under 400 (I'm such a girl!) I am figuring I need to balance it so there is enough air to have flames out the top baffles and not off the wood itself? But the flames out the baffles only last maybe 5 minutes and then it settles down. Is this what it is supposed to do? I let it go down to coals at 11 p.m and then put in one split, the house was warm at 77 so I cracked the window in my bedroom (always have window in living room (where stove is) open 2 inches. I got up this morning where it was 35 outside and 71 inside, stove was coals and 175 degrees. Am I doing this right? I appreciate any comments on the secondary burn.
I think the stove I grew up with was easier, we couldn't see inside to see what was going on with the fire!
Karen
Karen
