Mouse home in the air intake?
Stoveman2
9
12420
I am thinking about restoring a Jotul F400 that has been stored in a shed for 4-5 years. I plan on new gaskets and glass but am concerned about whether Mickey and Minnie have built a nest in the air intake system. I set it up outside with a 3' chimney and tried to start a fire but everytime I closed the door the fire died - is this normal if there is no real chimney?
Is there any way to check out the air tubes without taking the bottom apart? I can deal with the grate and ash pan house but I would rather not take apart the bottom. I don't think the mice would be able to build one in the side panels but I am concerned about the bottom flat areas.
Thanks for any advice
That's common. No draft. The Castine needs decent draft and 3' is far from enough. I've had a challenge getting a good fire going with the door closed with easier breathing stoves with a short stack outdoors.
Thanks begreen. Any advice on how to check the air intake system just in case
It's cast into place so not the easiest. You might be able to snake in a bottle brush through the intake hole and fish around.
I was afraid of that! I'll try the brush. I am going to try air pressure and a plumbers snake too. Thanks again.
I don't know if you can get front to back access via removal of the doghouse cover. Maybe pull it and shine a bright flashlight in the rear intake hole toward the front to see if you see light in the doghouse hole. If you can, then that is the direction to snake.
Sounds like a plan. I will not be able to work on it for a bit but that is definitely worth a try when I get back to it. I will let you know how things work out
Put a 16+ ft stack on the stove and feed it dry wood. It will be a different beast.
Thanks T-roy for the suggestion. That is on my list to try but I am not sure about how many directions the air goes and what the pressure will be by the time it gets to the back air inlet. Guess I will find out!
I wouldn't do that unless absolutely necessary and then only toward the rear from the doghouse - and that's still a maybe. My concern, if there is debris, is that one might end up accidentally blowing crap up into the side passages that feed the airwash or into the secondary supply.
That doesn't sound good. My intention was to go from the doghouse toward the rear. Think I will use that as a last resort. My other thought is to get any debris hot enough to burn off to ashes. Hope to work on it in the next few days
There's a good chance that nothing is in there blocking anything except maybe spiderwebs.
You are probably right but you haven't met the mice in my neighborhood. Maybe I will just do the 15' chimney test and see what happens
I ran a snake through and it went through both sides without much struggle so I think your right about the spider webs begreen. Thanks for all your suggestions and I will be trying a 15' chimney after I replace all the gaskets.
For 12 bucks you can get a usb or wifi video inspetion camera with led light for a smartphone. Mine has a 16 foot cable for a long reach. Not a bad thing to have in your toolbox
