I've read a lot of threads and other posts related to the Mt. Vernon AE auger jammed error code, but haven't found anything with my issue. We just purchased our house in the fall and it came with the stove. The stove turns on and works for about 45 minutes to an hour and then the error code shows up. I have to unplug it to reset it. I've taken the auger apart several times and there isn't an actual jam. It only seems to happen when it's below 40 degrees, of course that's when we really need it to work properly since it is our primary heat source. These are all of the things that I have done.
Cleaned the optical sensor, replaced the sensor, replaced the auger motor, and finally replaced the control board thinking that had to be the problem. Nevertheless I'm still getting the error message. Also cleaned it several times.
What am I missing? I'm completely fed up with this stove.
